utah Moab trail lengths
Posted (edited)
Does anyone have the individual trail lenghts of trails in the popular Moab ares...
Sand Flats, White Wash, Sovereign, Prichett Canyon/Kane creek, Poison Spider/ Gemini Bridges areas.
Trying to figure out a fuel statagey. We will be trailering to the differnt trail heads each day.
2 of the bikes only have a 60 mile range
Thanks, Shawn
Edited by NPWR250
I would recommend getting the Lat 40 map they have a millage and in my opinion are the most accurate. You can order them direct from their website  https://www.latitude40maps.com/moab-west-trails/
They have other maps as well but I think from what areas you asked about this one is best.
Remember a 60-mile range means before you get to 30 miles you should be headed back!!!
I have ridden all the trails you are asking about, the problem is always getting lost or just exploring different areas is where you can get into trouble with the very limited range they have. On more than one occasion I have had friends say they have "X range" only to run out of gas before we have gotten home. If in dought I recommend carrying extra fuel in a pack. Ya I know that sucks but running out of gas sucks even worse.
Personal experience tells me I can get from 70-120 miles out of my tank depending on how fast I'm riding! Had a buddy tell me he had a 120-mile range in the high country only to run out of gas at 72 miles because he was on it down in Moab. Bigger tanks ROCK!!!
Thanks, Shawn
Kane Creek Pritchard is under 50 miles: https://www.alltrails.com/explore/recording/kane-creek-pritchardt
Poison Spider across Gold Bar only 22 miles one way, so about 40 miles if you loop on Road or out and back in some form.
Sovereign with Seven Mile to make a loop is only 35 miles: https://www.alltrails.com/explore/recording/sovereign-to-seven-mile
White Wash if you do Enduro Loop and Dead Cow as a loop and stage from near the airport it is 60 miles, so for that you would need to decide where to stage and how much exploring you do. https://www.alltrails.com/explore/recording/emduro-dead-cow-red-butte
Slick Rock with Fins n Things and Porcupine as an out n back is 46 miles: https://www.alltrails.com/explore/recording/slick-rock-find-porcupine
Metal Masher to Hell Roaring Canyon is 50 miles: https://www.alltrails.com/explore/recording/metal-masher-to-hell-roaring-canyon
Pritchett (if you actually ride up ad down the canyon) is probably more dependent on skill than fuel capacity. I have heard of it taking groups several hours to go one way in there. If skilled can be done in .5 hr or less. G
+1 for the Latitude 40 maps.  It shows lengths of all the trail sections.
Sounds good , thanks for the info.
I got the maps. Lat 40 and Nat. Geo
I've found that the Nat Geographic maps are older and a bit outdated. If you notice a difference between the two, the Lat 40 is the most accurate.
If you go to utahmountainbiking.com they have extensive trail information for the Moab area.
Agreed.  That site is a great resource.  As is mtbproject.com.  However, as far as I can tell, neither tells you if they are closed to motorized users.  For example, Sovereign trail is single track that's open to motorize use, but many are not.
