Bret Morey
Dash lights too bright
Do any of you consider the highbeam, turn signal, and neutral indicators on the DRZ to be too bright.  Mine throw so much glare into my field of vision when riding at night that they are beyond just distracting.  They bother me so much, that I find myself avoiding using my high beams because the indicator is so bright.
Does it bother any of you.  Have any of you found a solution?
-Bret
When i first got the bike i found them too bright, now it doesnt bother me.
The window tint film will do the trick. Just get one that you can remove and reapply so if you dont like it you can just peel it off.
Yes, drove me nuts. Played with loads of options and rearrange so that I do not see them except for temp and flasher. I changed to opaque leds but yes they did.
Just go to your local window tint installer and grab a piece of offcut from the bin.
I will be doing mine but still busy with work so unable to get the time to work on bike.
Edited by MotardMadKiwi
I have that area blocked by the DRC offroad mirror, and I can see the glow/reflection on the top of it. But as most people recommended I would use window tint film, and not the spray unless you plan on taking the speedo out to spray it. It would probably take 5-10 mins to apply that much film and squeegie it perfect, the trick would be to find such a small amount of tint since they typically sell it by the roll. Maybe if you have a place that does window tint in your area they can give you a fabric swatch size that was left over.
if its in your line of sight your likely sitting too far back on the seat or you are just really short.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
