Newbie clutch bleeding help
Sorry if this question is already covered but did a quick search and didn’t see. Never had a issue bleeding brakes.
2003 ktm 525mxc. Recently purchased, newbie to ktm, rebuilt leaking resi on bars and now matter how many times I bleed/reverse bleed, zip tie trick overnight I cannot remove all the air at the resivoir.
But clutch works/feels great after 4 running hours and doesn’t have external leaks.
Where’s the air coming from? Can it leak internally on what I guess is the “slave cylinder”?
Thanks Billy
2003 that keeps getting air in the system- 15 yr old bike. Slave cylinder O ring or rebuild the master cylinder, or both.
Thanks just learned about the slave oring leaking internally.
The exact replacement o-ring is a 2-021 which can be sourced anywhere where o-rings are sold like Hydraulic Power Sales, Napa, Ace Hardware etc.
  • Like 2
