EXC 500 tire size
I’m wondering what size tires everyone is using. My 500 only sees dirt, the front is a 90 and the rear is a 120. I’m wondering if I should go slightly bigger. I ride a lot of mud, rocks, roots, double track, logging roads and some single track.
Cheers.
that combo size is same as mine 2017 500, I use the Tubliss system to lock the bead and rim the rear is Kenda Parker DT at 4 psi front is Goldentyre Fatty at 8 psi  been running this for about a year on second set of rubbers with same tubliss have had 0 flats and they stick to everything just by adjusting psi
Totally depends on the tire...
Going to a better tire for your terrain will make more of an improvement than 10mm more width. That, and the size stamped on the sidewall is just an approximation. One manufacturer's 140 might be the same size as another's 120.
  • Helpful 1
