96 kx 125 oil leak
Got a leak I can’t really pinpoint happened after I used my choke to start my bike after a while. Any help appreciated
Maybe from the power valve? I know it can get pretty messy in there and if your gasket is bad it might leak that splooge.
7 minutes ago, hansonj091 said:
Read more
Read more
What gasket do you speak of?
I'm of course more familiar with my YZ but
commonly 2-stroke MX powervalve housings are vented to atmosphere
and any excess unburnt premix that accumulates in there can easily drip out.
In the event your KX by design isn't vented or, the tube has a blockage (pinched, caked with mud etc.)
if the powervalve shaft / rod end seal is worn, it can allow the excess oil to drip
into the PV linkage cavity where your leak seems to be coming from.
The seal is part number #92049 in the fiche below:
https://www.kawasakipartspitstop.com/oemparts/a/kaw/500b23f1f8700223e478ca60/cylinder-head-cylinder
Edited by mlatour
