98 Yz250 hand levers
I have a 98 yz250 and have had problems with broken clutch handles... I want foldable clutch and brake handles but I can only find them for 2010 and newer. Any idea where I can find some or if the newer handles will fit my older bike?
This will work from Rocky Mountain you may want to call/confirm to be 100% sure. It may be a good idea to put some hand guards on there (bark busters) and then you can just run the stock levers.
The controls always get messed up when you take a spill and cost a lot of money to fix.
https://www.rockymountainatvmc.com/p/1036/57718/Tusk-D-Flex-Handguards-with-MX-Shields
https://www.rockymountainatvmc.com/p/3116/32744/ASV-C6-Series-Pro-Clutch-Lever?v=2262
2 hours ago, Colton Lee Doyle said:
I really pretty much only ride mx
That is the Clutch one you might shop around to see if they got a Brake Lever that will work (or find another Brake Master cylinder that allows the break away lever).
