Klr cam chain tensioner
Does anyone know if the cam chain tensioner spring should have a pin inside it to keep the spring straight mine doesn’t I’m thinking of adding a hardware store tension pin if anyone knows how long it should be lmk tia
Not that I'm aware of . Some that I've seen have a length of tube/rod as part of the bolt but otherwise the spring just goes in the tensioner as-is . The bore is usually small enough to keep the springs fairly straight .
Edited by jjktmrider
