Clutch Basket Wear
Hey everyone,
Wanted to get some insight on if this basket looks like it can be reused.  My hub is pretty chewed up and shot.  It also looks like some of the outer edges are uneven and slightly warped.  The backstory- the kid who owned my 500 before way over torqued every part of the clutch components, looks like he used a screwdriver to try and get everything tightened, and broke a spring bolt off in the inner hub.  The center of the basket definitely shows some wear.  Thanks in advance.
The rub marks are from someone leaving out the spacer/washer that goes between the inner and outer baskets. Don't really see any notching on the basket ears. But there is nothing wrong with new stuff. Just make sure to install the washers and other parts where they belong.
