Drowned Ktm exc 200 advice
At the weekend I dropped my bike in a river crossing, it was submerged completely under for around 30 seconds, was out in the sticks so had to get it started and ride on which I managed to do, drained water out exhaust, squeezed air filter out, and took plug out, anyway it started after a while of trying, I have drained the gear oil out as it was milky, and flushed it a few times, have drained the carb, changed the plug and filter, anything else I can do as precaution, I’m worried as the engine has only just been rebuilt, any opinions and advice would be good.
Thanks
30 seconds!?  What'd you do, float away?  ;)
I'd make sure to get some more hours on it if you were about to put it away for the season.
Yes pretty much what happened 🙈 will defiantly be putting hours on it, normally do around 10 hours a month, I have just took the exhaust off and this is what the cylinder looks like, any input? Fresh piston 5 hours ago, cleaned up cylinder with scotch brite, can’t remember these marks being there! Think it’s just me panicking! 0F95E14A-CF75-4530-9E95-C6052F1F2403.thumb.jpeg.1696af9441426882cba8c3458e61f39a.jpeg
Did you do a compression test after the rebuild?  How does the reading compare now with the vertical scoring?
I think you're in good shape.  The important thing is to get it started right up ASAP, which you did.
Sometimes you have to change the oil a couple times until it isn't milky.
I would flush the bottom end with wd-40 or any lubricant with water affinity.
2-strokes have a tendency to evaporate the water and some condenses  on the underside of the piston. When the motor cools down, the condensed water drips right own the rod to the big-end bearing.
I have known several bikes that lost the big-end bearing some time after being submerged.
Me personally I’d split the cases to get ALL the water out.  You never know, and it’s not worth losing the big rod bearing which is likely.
:cheers: You did the correct thing as to empty all water out of exhaust ,air filter, after home, clean air filter or replace, also change oil after a hot long ride, keep an eye on gearbox oil and replace if gets cloudy again, I had a 84 yz490 that got dropped when I got on slick rocks coming out of a creek bed, and she went totally under, I did all the same as you and cleaned air filter and box after the ride and did 2 gearbox changes and never had any problems, i enjoyed the ride,...and the garage time later,.....:thumbsup::ride:
  • Helpful 1
Thanks for all the relplys! I rode the next day on fresh oil, filter and plug as was a weekend trip, the bike defiantly got hot on both days after the drowning, in reply to compression test question, I never checked the compression after but it felt noticeably better, and still does, I know I should have done but I can’t change that now, what’s opinions on the scoring?
Thanks
:thumbsup: From that pic its hard to tell, you could do a comp test and keep track,  or if you want you could use a bore scope and go through the plug hole to actually look at it , but most scopes are bigger than the plug hole..at least the ones ive seen for cars and trks... if your comp test shows close to normal, keep a clean air filter in her and ride on...:ride:
Quick update so this evening I whipped the head off for a better look, it’s scored but I can’t catch my finger nail on anything, feels the same all the way round, few pics, I think it looks worse than it is but I’ll see what people think.
The cylinder looks useable aside from the fact that it appears you've worn through the Nikasil over the exhaust port.
I don’t think the scoring was caused by water, I think it is how the piston is running in? What’s your thoughts on this, would you run a bike with it like this? No performance defects, just abit worries about it!
