ENZO Fork Oil
I was doing an oil change on a set of forks revalved by ENZO with about 20 hrs from a 17 CRF450r. The oil in the outer chamber was clearly not your usual oil and was very thick/slippery feeling. Like a drip would stay connected and make a long string 6 inches or so long. I've seen stock oil like this on Hondas 10 or years or so as well but never found it in a bottle. haven't had a chance to call them but they only list KYB 01 oil on their site which I'm pretty sure doesn't act like what I described.
So what kinda oil is it?
...maybe you don't wait enough between two oil changes...
jeanjean
jeanjean
So your saying the older it gets with use the more gooey it gets?
The KYB 01 doesn't act like what I pulled out, not even close.
I talked to Enzo and they said they only use 01 and think someone must have done something after them...?
If Marzocchi was really using Spectro sae 7.5 oil (in rebadged containers), maybe it's a Spectro.
That oil was like heated butter. It was staying on the fork walls like glue. I suppose this is exactly what you don't want on a suspension oil....
