Hey guys I need some help with my 1982 XL250R it currently has no spark
also having some issues with indicators and the headlight
when I turn on the headlight the indicators stop working all together and can’t be turned back on
the headlight when it’s on does not work well
if somone knew a lot about these it be great for some help
cheers
Headlight should not be on without the engine running, and blinkers often dont blink properly only running from the battery without the engine going.
  Spark issues seem easier to find by starting at the plug and working backwards, IE Plug,cap,lead,etc.
Check grounding and connectors etc too.
I'd suggest a wire is shorting, possible rubbing against the frame.
Disconnect the battery, check for spark, if no spark check your spark plug connector and line. Bike should run and start without battery. Agree with Muzz67 above. I recent,y had electrical issues with my bike, it was a faulty connection and I just needed to push a connector in firmly. With the tank and seat off do a visual inspection of connections before getting into the headlight. Look for anything rubbing against the frame.
Hey guys thanks for that
ive discovered that there is power going through the ground/earth wires when I kick it over
so when I kick it over the test light lights up on the ground wires power is being sent through those wires
hope this can help figure out why
its getting power right to the cdi coil I’ve changed to a new coil still getting power there just not getting to the lead I’ve changed leads
