TTR 225 clutch won’t disengage
Got a project 2001 to fix for grandson.  Really abused!  Clutch is always engaged.  Disconnected case end of cable to operate clutch manually but no effect.  Pull clutch side case?  What to look for?
So you are saying that you tried to move #22 by hand and the clutch basket didn't move?
This is generally what you are looking at on the inside of the clutch cover. If you are confident the cable and the handlebar lever are operational and the clutch still doesn't release, then yes, I'd say you need to remove the clutch cover and take a look at #5, #22 and #26. Order a new gasket first so you have it on hand. Might be just stuck clutch plates and old oil.
image.thumb.png.ee73084ff2d257e31b4ffa25d2346309.pngimageproxy.php?img=&key=b3312acf975e3c54imageproxy.php?img=&key=b3312acf975e3c54
Edited by Augoose
