Removing baffle on 2007 CRF230f
Hi So I have been looking into uncorking my 230 and I have seen people removing the baffle. But They said that it makes the bike louder and In Idaho for trail riding which is what I do The bike cant be louder than 96 DB. So Does anyone know how loud the bike is without the baffle cause I really don't want to get pulled over and get a ticket for it.
Thanks
Simply remove it and do an “A” - “B” test and then tell us what you think about it. (After/Before)
I measured mine at 86 dB with and without (open) the "Bikers Choice" baffle. I do not have a stock baffle for comparison.
Scroll up to "Sound level measurements" here
http://bit.ly/2zFwpF3
Edited by RedMesa
Well, I did a test but I don't have anything to measure the dB But it was loader and sounded less choked But based on What the link red mesa gave it looks like im fine. If anyone finds anything different let me know.
Changes in the exhaust do change air flow thru the engine and if the cam has a lot of overlap reversion can affect jetting. I had this problem with my 218, the cam has 40 degrees of overlap, twice what a stock 230 has.  The X engine also has only 20 degrees of overlap and removing its baffle improved bottom end.
So sometimes you get unexpected results.
https://thumpertalk.com/forums/topic/1275682-quieter-alternatives-to-removing-the-baffle/?do=findComment&comment=14540144
