1985 Honda XL350 rough running and high idle
Hello everyone,
Hopefully I posted this in the right section.
I am having a problem with my XL350, after a couple of kicks it starts but the idle is all over the place, sometimes it will even die at idle. I have sprayed carb cleaner around the carb and around the boots but there is no change in idle so that tells me that thete isnt a vacume leak. I have also checked the valve clearance and they are within spec. I have the carb set at the factory setting at  2 1/8 turnsout.  The stock jet sizes are there. There hasnt been any modifications I'm starting to run out of ideas and any suggestions would be great
Thank you
- Mike
Also when it gets to operating Temp the idle jumps up crazy high sometimes it climbs back down but for the most part it stay high until I shut the bike off to cool down
