2017-2019 500 EXCF ignition relocation
This needs to be a sticky, or whatever you want to call it, for these model years. These parts come from earlier model years and allow you to relocate the ignition so you can more easily get your key into the ignition from the right hand side while sitting on bike.
KTM part #s:  78111065050. Ignition lock bracket
                         58411066450.  Ignition lock washer
these parts are about $5 each.
Don't the '17+ have the ignition right behind the front number plate?  Isn't that an easier place to get to than down low on the right side, like it is on the previous bikes?
I have a '16, and while I've gotten used to it, I've often thought that it would be nice to have the key up top behind the number plate...
On my 2018 it’s difficult to get to the ignition and as soon as you add a set of Handguards it’s near impossible. If they changed this to make it easier to get to the key they failed miserably.
Edited by DanHall
59 minutes ago, StevetheSnake said:
... The key doesn’t bother me at all, it’s well protected and out of the way. 😉
This is actually one of the things that I don't like about the position that it's in prior to '17, and if you use the pieces indicated in the original post.   While I've never busted off a key, I have hit that corner on bushes or smalls trees in tight single track, and I'm always worried about busting the key off...
  • Helpful 1
Hahaha ask Dan to send you his. 👍
But I agree the one on the side down low looked a little bit prone.
Steve the snake.  I guess it’s all personal taste. Oh well enjoy the bike. It’s a beast.
Edited by DanHall
  • Like 2
dude that bike is so purdy , mine look like that for a week .
Highway Dirtbikes makes a clean dash that relocates the key.  Only problem for me is that it doesn’t work with a damper.
Can't picture that not working with a sub mount as the Scott's is on the "90 mm" side of the bar center. Old version below.DSCN1087.JPG.fcda7911fba7646361860f06f230cc63.JPG
I am sure it would work with a sub mount.  My damper is above the bars so I can easily switch it between two bikes.
Good point
I don’t usually hijack, but is that a 991 turbo in the background?
997 turbo. Good eye.
Edited by DanHall
well I knew I had to relocate the key on my 18, and was set on an HDB dash kit. Then motominded had to come out with their new mount and now your posting this..
first world problems
Hows this for good eye......      Somebody put your WP fork leg stickers on backwards~~!
Yes, there is a left and a right.
9 hours ago, Lee1200 said:
Thats a sweet setup, is the Display Mount required? or can I get away with just the modular dash?
