Will 1981 CR250R hub fit on 1983 CR250R forks?
I am building an xr200r for vintage racing. I have a set of 1983 CR250R forks (43mm) and would like to use a brake/hub assembly from a 1981 CR250R (41mm). Anyone tried this before?
NOTE: Both have the brake stay tab at the 2 o-clock position and use the same axle. Unfortunately, I cannot mock it up as I will have to buy/ship the '81 hub. Why the '81 hub? I found a '81 brake/hub assembly that is essentially nos.  My '83 brake assembly/hub is best described as 'rough' will require significant work to rehab, including TIG welding the brake spring tab that is broken off.....
Thanks in advance.
