Hey guys my 17sxf350 seems to cut out randomly at idle it runs fine otherwise up in the higher revs could this be a fuel filter problem
Not likely but I would look anyway
Known problems are
Dirty inline fuel filter
Dirty main tank filter
Kinked tubes in tank from pump
Damaged tubes to pump
Weak pump if ran with dirty filters ,burns out the pump
You can clean the inline one but I replace them ,the tank one you replace
Done all the fuel filters today still the same any other ideas?
Is your idle too low ? Could be a air leak at the exhaust ?
how many hours on the bike? have you checked valve clearance? have you checked the spark plug? Also make sure it has brand new fuel.
So I have just pulled the injector and back wash cleaned it and it seems to run good in the garage.will take it for a ride this weekend and see how it goes.i think I'll check valve clearance Next Week and throw in a new plug while I'm at it as it has 92hrs on it so must be due
