After market solenoids any good ?
Has anyone had success or otherwise with after market solenoids or is OEM recommended here ?
Solenoid for what?
7 hours ago, Trailryder42 said:
Solenoid for what?
starter solendoid exc300
Why do you need to replace this?  I've never heard of one going bad on a dirtbike...not that it can't happen.
i get the impression on a ktm this is a weak part, and mine is toast. I can make it click but there is no electrical join between battery and starter when i do so.
If its clicking, its most likely working. I replaced a clicking solenoid on my sons 230f and it still only clicked, it was the battery.
I also just last week thought I had a bad solenoid on my ktm250xc, just clicking, it turned out to be the starter.  I would double check everything, including the battery under load, make sure the volts don't drop off crazy, so you don't waste your $$ and time on a part that is not needed.
most likely agreed - but not in this case. if I bridge the solenoid with a heavy duty wire they starter turns
