Ben Gould
Oil leaking from stator
Hi everyone, I rode my crf250 to work, I know these bikes shouldn't be used for road driving, but I thought it would be okay, it was about 20 mimute journey, most roads being 30mph but two being 40mph and 50mph. On returning to my bike after my shift there was a small path of oil and oil on my bashplate, the next day I give it a test run and had the same again, I am 90% sure the oil is comming out of the stator wire grommet, as read another forum on here and kinda similair to my problem.... also is black wire/casasing mean't to have a gap in it like that?
Thank you very much
Thank you very much
There is a rubber grommet wonder if the crank case is over pressurized like clogged vent tube?
Hi clogged vent tube, totally lost me with this one mate?
Is the engine oil and tranny oil separated on this one?
What is the oil level (is the level correct) just trying to work through the items.
Yes the CRF250X has separate sumps for the engine and gearbox.
The engine shouldn't build any pressure in there as it's vented to the airbox and under a slight vacuum.
Perhaps a damaged seal.
Myself added some Yamabond type sealer around that triangular grommet due to it's location 'just in case'.
(debris always getting slung there from the chain)
Edited by mlatour
Engine and tranny oil are seperature yes. The oil level in engine was correct but due to the losing if oil (leak) min now.
Thank you
Okay thanks, another guy had the same problem and he did this to fix will give it a try at end of week if not other solutions, do you think take of the casing and have it look inside as will be doing an oil change anyway. Thanks
The pics suggest the oil is coming from around the wires rather than from around the grommet, correct?
Any movement if you gently push/pull on the wires?
Hi, no movement from wires and I think its is leaking from the wires....
A mechanic told me from a video I sent him that the sealant has failed on the stator wiring grommit, he said to take off casing, clean it up and apply new sealer and new gasket.... what do you reckon and how to find out specific gasket type.
Thank you.
No gasket type. My recommendation is to remove the case cover and clean the area where the wires go out thru the grommet with spray electrical spray cleaner, contact cleaner, or even  carb cleaner. And then seal the area with a RTV gasket maker. I like red because of its hi temp rating, but blue would probably be OK because the cases don't get too hot.
Thank you
