Help
1 hour ago, Gary McIntosh said:
Need help cant find a crank for my 1997 rm 125 Suzuki says its discounted..will any other year work?any help would be appreciated.  I'm in alberta canada
This what you need Pro-X Crank rod rebuild kit. The Crank will have to be pressed - see the link below.
https://www.ebay.com/itm/1997-1998-Suzuki-Rm125-Rod-Kit-Pro-x-Rm-125-Connecting-Rod-97-98/183403724646?epid=6018373366&hash=item2ab3b6bf66:g:xHkAAOSwrORbhYhk
https://www.acsmb.ca/services
A place like the link above most likely could press it. Then you need New Crank Bearings and Seals as well. Also, Pro-X makes a complete top end gasket kit and Piston Kit as well. Looks like the OEM center case Gasket is still available as well.
Edited by ar2stroke
