99 250 exc Fork issues
I have a 99 250 exc and I am trying to find some options for my forks. They currently seem to like to blow seals and the bushing are getting very hard to find. So I was wondering if anyone have ever installed different set up. They are way under sprung for my weight not sure if that could be part of the problem. I have not had my luck in my searches coming up with any good info. Thanks
I put 2002 forks on my 92, used triple clamp and front brake set up, front wheel and all. Just put 05 forks on my 02, wanted to go with the 48mm over the original 43mm. It is easily done but may require the use of front wheel and brake set up. I would recommend going newer as parts are easily assessable.
