how to tighten primary drive gear nut?
There is no forum on how to tighten these nuts. Only how to take them off with an impact. I dont want to put an impact on it to tighten it because I want to torque it to correctly with my torque wrench and dont want to &%$#@! anything up. How do you do this without buying the oem honda gear holder tool? Can I buy that tusk clutch holder tool and grab the clutch basket when it joins with the primary gear to stop it from spinning?
Edited by Ktm520sxrider
Wedge a small piece of aluminium or copper (like a washer) between the primary drive gear and the clutch basket gear,
it will lock them together and allow for tightening of the bolt.   (maybe add a drop of Loctite on that bolt for good measure)
Edited by mlatour
  • Like 6
I just either hold the rod tight and hit with 1/2" electric impact or hold clutch basket with hand . Not hard. This pic is how i tighten hub nut with impact too. Just apply pressure to plate and hold with hand done in two seconds
There may not be a forum that tells you how to tighten these nuts, but there are these paper things called shop manuals that tell you exactly how to do it...at least if you own a Yamaha. Can't say for a Honda. Piece of aluminum or a penny is actually the recommended method.
And just an FYI, personally I don't tighten any torqued nut with an impact wrench unless it's a lug nut. But that's just me. :ride:
  • Like 2
I let the kid down the street use my 1/2'' , 20 volt Dewalt impact gun to tighten his flywheel nut and he snapped off the end of his crank.   :facepalm:
  • Haha 1
?!!! Why was he using it on his crank? At that age I always used my hand unless I could get a date. Kids these days...
  • Haha 2
That's why I said I'm not buying the OEM gear holder tool for 80$ that the manual says to use so obviously I use my manual lol. Thanks for the input though. I didnt think of that penny method. it's a great idea. Wonder why nobody talks about that method. I couldn't even find any forum on it.
  • Haha 1
Lol that's why I'm never using an impact on stuff like this. I used it on my xs650 build for the clutch pack nut but only a quick zap with the impact nothing crazy.
Done hundreds of engines with impact.  Flywheel nut,primary bolt/nut, clutch hub nut and counter shaft nut/bolt. No special tool or holder needed can hold with hand if tough enough i geuss 🤣 you just dont go crazy with one the electric ones not as powerful as air one but still its a feel thing. Never had problems myself but to each there own
  • Like 3
Yeah your right just cant be an idiot when you use that tool. Id just prefer that penny method because I have a torque wrench I used for everything else and I like going by the book. it really is all about the feel with the impact. You can definitely tell when its tight enough to know not to overdo it but i just feel more comfortable torquing it with my wrench👌
Understood 👍
Although for this particular task I'd pick the wedge method and a torque wrench,
an experienced mechanic that works daily with an impact drill will get a good feel of how much is enough for the job.
For many years I worked at a truck assembly plant (Kenworth/Peterbilt) and you would be surprised with all
the somewhat delicate stuff that is put together with an impact (dashboards, interior liners and trim panels etc.) many even using plastics fasteners.
1 hour ago, Ktm520sxrider said:
That's why I said I'm not buying the OEM gear holder tool for 80$ that the manual says to use so obviously I use my manual lol. Thanks for the input though. I didnt think of that penny method. it's a great idea. Wonder why nobody talks about that method. I could even find any forum on it.
Reading comprehension fail on my part. Yamaha manual does reference an OEM part, a $3 square of aluminum. 🙂
Glad you asked about this. Probably saved several people money. And hopefully some will also learn the ridks of using an impact for tightening.
  • Like 2
It's a pretty cool tool to have if you build these every day but yeah I'm gonna jam the penny in it instead haha
Wow! That’s a nifty doodad. I’m not sure it’s worth 7200 pennies though.
Because its a great way to break a gear tooth, or bend a shaft, fracture the case
If your not going to use the proper tool at least jam the gears with a tool that takes advantage of full even tooth contact and does so in a normal manner like in use.. not wedging the gears apart with uneven tooth pressure points.
  • Like 3
How many pennies is that?
  • Like 2
  • Haha 3
