LED headlight for dual sport conversion
I dual-sported my XR600R a couple years ago by adding a Ricky Stator and Capacitor (battery eliminator) which ran the headlight (with high.low), tail light, brake light, blinkers, and horn. I was sometimes irked that when using the headlight, the horn was weak, and even weaker at idle. So I purchased a Cyclops LED bulb from ProCycle. It is plug-and-play, fits right into the socket where the H4 bulb was. They have a little fan and heat-sink attached to the rear of the bulb. Not only is it brighter and whiter, but since it draws much less wattage, the horn is now full blast even at idle. Highly recommended!
Edited by exaresix
  • Like 2
