dtallent Posted November 25, 2018 '85 xr600 leaks oil and smokes a little. So it needs gaskets and rings, is there anything else I should do while I'm in there? Started in a couple kicks after being left for a few months. Should I bother with the stator or anything else since it starts and runs fine? Is there a stator out there with more power output? Share this post Link to post Share on other sites
Cleon Arrey Posted November 26, 2018 Ricky Stator - DC conversion is the way to goooo. $300 of good glory. Aside from that, if it ain't broke don't fix it haha. Find out where the smoke is coming from first, then go from there. Could be a leaky head gasket that's dripping/burning on the heads. Share this post Link to post Share on other sites
bobcan Posted November 26, 2018 First thing you are gonna do is pull cam cover , then the head. Send your head out for a valve job at a good machine shop . Get a new cam chain . Put in a new oil pump assembly. That means a whole assembled unit . Check , Honda east Toledo and partzilla for prices. It's been a while but I think they were around $235 . I google a search for online Honda parts when i am pricing parts . If you spend bucks on a build and soon after your oil pump goes you'll lose everything you put into it and more . Clean the screen on the bottom of the down tube oil tank nipple where the black flex hose links the motor to the oil tank . Of course get a service manual . Oh. When you put the black flex hoses back on after you've installed the motored in the frame , be aware that you don't put a kink in the black oil hoses because you tighten the fittings and can twist it to the point of a stoppage of the oil flow . Again a catastrofic oil failure melt down . These are just some common mistakes people make . 1 Share this post Link to post Share on other sites
bobcan Posted November 26, 2018 I just went on ebay , and there is a partzilla marketplace . Brand new xr 650 l camshaft assembly is $161.74 ,Part #14000-MAN-690 . Brand new oil pump assembly is $109.51 .Cheaper than I remembered . Share this post Link to post Share on other sites
dtallent Posted November 26, 2018 Awesome. Thanks for the replies and will do. Don't know if wife will let me spend the money on a Ricky stator. Gonna be buying a new ktm adventure eventually. Share this post Link to post Share on other sites
