Cyclops LED Headlight Stopped Working?
I just installed a Cyclops LED headlight on my Yamaha XT250.  It worked fine when I tested it but after putting the bike back together it doesn't any more.  I checked the fuse (good) but there is no current at the headlight connector.  Any help would be appreciated!
I installed one on my WR250R and it worked for about half an hour before flickering and dying.
The plastic connector between the ballast(?) and actual bulb broke because of the quality of plastic and how thin the piece is. I called Cyclops and got a replacement and epoxied the whole connection with the new one together so it can't break.
Check the connector? ?‍♂️
Edited by pumpernickelBrad
Just checked my new Cyclops bulb and it didn't work.  I also installed a new fuse and still no power to the bulb connector.  I'm at a loss as what to do.  I have emailed Cyclops to see if they have any suggestions.
Thanks for you reply!
