SUZUKI RM 250rm
KICK START JAMMED, bolt snapped inside kick start mechanism as seen bellow in photo, I have no idea about engines, is this an easy fix or will that screw not be the cause of the jammed kick start?
Is this the same problem since your post of last March?
You seem to have posted many similar threads in the past few months,
it's not going to troubleshoot/fix itself by looking at it.
Buy a service manual and start taking it apart and investigate what's going on
or, bring it to someone else to repair.
Doing this now, haven’t been able to but I’ve got a lot more spare time now, tbh I was just wondering if that could be the cause, and how to get that snapped bolt out?
The snapped bolt is stuck inside a shaft, for now it's the least of your worries.
It won't prevent you from disassembling the RH side cover to find out what is causing the lock up.
In a word, No.
You're going to have to get your hands dirty. If you drain the oil and take that cover off, i'm certain you'll find the cause of the jammed kickstart , and you'll also be able to take the shaft to someone to remove the broken bolt, in the event you can't figure out a way to do it yourself.
