2009 TTR 230 tail light/brake light wiring
I bought a tail light/brake light from Rocky Mountain atv for my 2009 TTR 230. I have everything wired together the way I was told to do it but when I turn on the power nothing happens. Maybe I have it wired wrong. 3 wires come out of the light. Red, yellow, and black. The black I used as the ground, The yellow I ran to the brake switch and then to the starter and the red I connected to just the brake switch. This is my first time trying this so it could be very wrong. Anyone know where each wire connects to or if I am missing something?
Thanks
Did the kit come with the switch?  I assume so because there is no brake light switch on the bike... would have to see the wiring diagram how you connected everything,
Got a link to the kit/ instructions?
I got it figured out today. I didn’t wire the hot wire correctly. Was having the same problem with wiring the horn but I went down to my local Yamaha dealership and they explained how I should do it. Thank you for looking into it.
