CRF230 Tire Pressures in the sand?
What tire pressure should I run, front and back, on a CRF230 for Florida sand trails?
Since you couldn't find a rock in FL if you wanted one, I'd go with 12 front, 10 rear at the lowest. If you're worried about roots at faster speeds, bump each up 1-2 psi. Assuming you have rim locks, yes?
Also what tubes? I like the IRC 3mm tubes. I have a M59 in the front And a X30 on the rear. And run 9psi. Both ends. I may raise or lower them 1 pound. Depending on conditions. Also the Bridgestone tubes are very good.
6psi rear tire a bit more in front.  You can run 6psi front if you’re not hitting bowling balls size rocks at 50mph.  You’re rim locks need to be correct.
You got it baja Hooter 4mm tubes we run 6pasi front and back. Lots of sand here
