Tanner Black Posted November 27, 2018 I’m new to bikes and I bought a xr650l 2005 model if that matters. Anyways I want to check spark in the bike but my starter is bad so is there a May to check spark without starter working any help would be appreciated thanks. Share this post Link to post Share on other sites
Hollerhead My Ride Posted November 28, 2018 (edited) Not an easy way. It will make a spark if you have a decent battery and push it in gear but you'd be a talented dude if you could do all that and watch for spark. I guess you could run a jumper wire from the plug wire and bite on the bare end to see if it makes you see stars...? Edited November 28, 2018 by Hollerhead 3 Share this post Link to post Share on other sites
XR650L_Dave Posted November 28, 2018 You could secure the bike with the rear wheel in the air, take out the spark plug, and rotate the rear wheel in 3rd gear or so. Share this post Link to post Share on other sites
ScottRNelson My Ride Posted November 28, 2018 Do you know what is wrong with the starter? If you take a heavy wire and jump from the positive side of the battery to the power post on the top of the starter, does it turn the engine? If not, you can rebuild the starter for a reasonable amount if you're even mildly mechanically inclined. If you don't want to rebuild, I have a spare starter that I bought when my starter died, before I rebuilt the original one - I'll make it available for a reasonable price. I'm pretty sure holding onto the end of the spark plug wire, or holding the spark plug in your hand when turning the engine over will let you know if it is producing current for a spark. Much easier than trying to see the spark, although "a bit less pleasant". 1 1 Share this post Link to post Share on other sites
ericsXr600R Posted November 28, 2018 Assuming your goal is to have a bike that runs, I wouldn't worry about spark until you figure out your starter issue. Once you get it to turn over we can help diagnose any running issue you may have. 3 Share this post Link to post Share on other sites
usedtobefast Posted November 28, 2018 Step 1 - check the voltage of your battery. Meters to do that are pretty cheap. If that is low, then you could try charging it. Also, many auto parts places will check your battery for free, maybe go that route if you don't have a meter or battery charger. So ... with a healthy charged battery ... what happens? Starter spinning the motor over nicely but it isn't starting? Or starter not spinning the motor over? Not sure how long the bike has sat ... but the most common issues are weak/dead battery and clogged pilot jet in the carb. Share this post Link to post Share on other sites
Tanner Black Posted November 28, 2018 I did take a set of jumper cables and connect it to the battery and the starter and it turned over But there is still no spark so what’s next because I’m not too sure thanks for all the previous help Share this post Link to post Share on other sites
doug the slug Posted November 28, 2018 I'd begin with testing the switches - kill switch, key switch, etc. Likely something simple caused this. Share this post Link to post Share on other sites
JoeRC51 Posted November 28, 2018 (edited) Are both the key AND the kill switch on ? Honda's will still turn the starter with the kill switch off. Does the starter not work by the button because you blew a fuse ? Edited November 28, 2018 by JoeRC51 Share this post Link to post Share on other sites
ericsXr600R Posted November 29, 2018 Look at the easy stuff first like Joe stated. The starter will spin if you put power to it, but if the key is off it won't spark. After that I would bet on a bad CDI. Share this post Link to post Share on other sites
