espey34 Posted November 27, 2018 Hey guys just wondering if anyone can confirm if a set of wheels from a 09 530 exc will fit my 501. Found a local set of used supermoto wheels and would like to grab them if I can confirm they will work Share this post Link to post Share on other sites
1 lunger Posted November 28, 2018 Yes, but will need to use the spacers from current bike. Share this post Link to post Share on other sites
Filipe Posted November 29, 2018 I was thinking the axles are different diameters, which would require different bearings? It would behoove you to bring your axles with you and check the fit. Share this post Link to post Share on other sites
eastreich Posted November 29, 2018 14 hours ago, Filipe said: I was thinking the axles are different diameters, which would require different bearings? It would behoove you to bring your axles with you and check the fit. Bearings are all the same. Only difference is wheel spacers to accommodate the change in axle diameters. I have OEM hubs/bearings from my 2008 KTM on my 2018 Husqvarna... Share this post Link to post Share on other sites
