Rakenjake Cole Posted November 28, 2018 So here's how it goes got a fairly used drz was it 3500 miles on it it worked good great until today ! I went to do a simple sparkplug change in the hole switched them out . And here me I did everything right I took it out put non sieze on it put it back in tight .tightened it then tightened it 1/3 tighter put gas back in it and even gapped it to 0.8 .and after that I drove it around town and it shut off on me in 5 th gear and continued to do it for the rest of the night . Any body have suggestions to why this is happening Share this post Link to post Share on other sites
CCampbell27 Posted November 28, 2018 Did you have the spark plug to tight? Share this post Link to post Share on other sites
Chicken-N-Waffles My Rides (3) Posted November 28, 2018 So here's how it goes got a fairly used drz was it 3500 miles on it it worked good great until today ! I went to do a simple sparkplug change in the hole switched them out . And here me I did everything right I took it out put non sieze on it put it back in tight .tightened it then tightened it 1/3 tighter put gas back in it and even gapped it to 0.8 .and after that I drove it around town and it shut off on me in 5 th gear and continued to do it for the rest of the night . Any body have suggestions to why this is happening Why would you change the plug at 3500 miles? Share this post Link to post Share on other sites
mlatour Posted November 28, 2018 (edited) 41 minutes ago, Rakenjake Cole said: put non sieze on it as in anti-seize paste ? A small amount isn't a problem, slathered on perhaps so. Had you ridden the bike in the same fashion previous to replacing the plug? if not, the issue could be entirely unrelated and was present before the change. Edited November 28, 2018 by mlatour 1 Share this post Link to post Share on other sites
