Is this JUG still good?
Going to freshen up the piston however i noticed some small streaks on cylinder wall really minor and can barely feel with my nail, how bad is it.
Basic rule is, if you can catch a nail, you need to service the barrel. However, being your 'mess' is at the bottom of the barrel (so to speak), you might be able to remove it with a little muratic acid if you are up to it. I assume that is piston material and not a plating problem.
3 hours ago, William1 said:
38 minutes ago, bubba79 said:
from the pic it looks good to me, id run it
Thanks, im going to i doubt it will cause any problems, this is from a bike with pretty low hrs.
36 minutes ago, Chin Strap said:
I've heard those kind of marks can be left by a ball-hone, can anyone confirm that? Just curious.
The cross hatch yes but not the vertical lines OP is referring to.
Try a light hit with scotch brite and they might come out.  Looks good to go though.
