Simon Aamand Enevoldsen Posted December 2, 2018 so i just got a ktm 125 2005 and it couldent evan keep up with a yz 85 so i oppened the power valve inspection port and when i turn the adjuster it seems like there is a lot of slack in it how do i solve this problem? Share this post Link to post Share on other sites
7Tktm Posted December 2, 2018 Hi, with the left hand pv cover off (the one with the breather pipe) check that the valves are opening. Give the bike a real hard rev and you should see a bracket with a stroke in it turning down to the bottom of the 'window' and returning back up to the top as you return to idle. Check that first. Bob Share this post Link to post Share on other sites
seer Posted December 3, 2018 The valves in the head are all gear driven. Mine had slop and needed replacement. As it was the transfer ports would only open about half way. Yours sounds like possible wear at the governor attachment. Share this post Link to post Share on other sites
Simon Aamand Enevoldsen Posted December 3, 2018 4 minutes ago, seer said: The valves in the head are all gear driven. Mine had slop and needed replacement. As it was the transfer ports would only open about half way. Yours sounds like possible wear at the governor attachment. and is that an easy fix? Share this post Link to post Share on other sites
seer Posted December 3, 2018 1 minute ago, Simon Aamand Enevoldsen said: and is that an easy fix? I cant say whats easy for you. You need to pull the cover off to replace but i wouldnt order anything before diagnosis ing. Share this post Link to post Share on other sites
Simon Aamand Enevoldsen Posted December 3, 2018 (edited) 5 minutes ago, seer said: I cant say whats easy for you. You need to pull the cover off to replace but i wouldnt order anything before diagnosis ing. and how do i know for sure its the governor attachment? and if it is the governor attachment where can i buy a new one an not an used one Edited December 3, 2018 by Simon Aamand Enevoldsen Share this post Link to post Share on other sites
7Tktm Posted December 3, 2018 (edited) Hmm. Have you checked that the valves are opening yet when you rev the bike? It is the most common problem. The 'governor' or centrifugal timer is a foolproof mechanism. The only thing that goes wrong with it is for the one or more of the 4 ball bearings jumping ramps which stops the valves opening fully. Easy to fix yourself but you would need to remove the clutch cover. You would be best to check the valves are opening first to ensure the system is actually connected, but if you don't want to then it's up to you. Bob Edited December 3, 2018 by 7Tktm Share this post Link to post Share on other sites
Simon Aamand Enevoldsen Posted December 3, 2018 1 hour ago, 7Tktm said: Hmm. Have you checked that the valves are opening yet when you rev the bike? It is the most common problem. The 'governor' or centrifugal timer is a foolproof mechanism. The only thing that goes wrong with it is for the one or more of the 4 ball bearings jumping ramps which stops the valves opening fully. Easy to fix yourself but you would need to remove the clutch cover. You would be best to check the valves are opening first to ensure the system is actually connected, but if you don't want to then it's up to you. Bob i haven't checked yet because its late when i come home from work and i woudent like to piss of my neighbors Share this post Link to post Share on other sites
7Tktm Posted December 3, 2018 (edited) Ah, ok. There is a process you go through with the power valve which is a very simple but good system. First is to make sure it is meshed. If so then move on to next stage. All it requires is a quick rev, even when cold, to see if it is opening. We run our bikes up and down the street when issues - must have good neighbours. Bob. Edited December 3, 2018 by 7Tktm Share this post Link to post Share on other sites
Simon Aamand Enevoldsen Posted December 4, 2018 16 hours ago, 7Tktm said: Ah, ok. There is a process you go through with the power valve which is a very simple but good system. First is to make sure it is meshed. If so then move on to next stage. All it requires is a quick rev, even when cold, to see if it is opening. We run our bikes up and down the street when issues - must have good neighbours. Bob. i have just checked and it seems to be opening but the mark in the power valve i way beond the 2 marks on the non moving part. and when it opens it goes down to the top mark Share this post Link to post Share on other sites
7Tktm Posted December 4, 2018 (edited) Hmm. For the factory setting (which we prefer) - when idling the inner stroke should be higher than the fixed lines then when you rev it hard the moving line travels down almost out of sight at the bottom of the inspection window. That is how it should be set to give you power through the whole rev range. Have you tried adjusting the moving stroke back up to the top then see how far it travels when revved hard Edited December 4, 2018 by 7Tktm Share this post Link to post Share on other sites
Simon Aamand Enevoldsen Posted December 4, 2018 32 minutes ago, 7Tktm said: Hmm. For the factory setting (which we prefer) - when idling the inner stroke should be higher than the fixed lines then when you rev it hard the moving line travels down almost out of sight at the bottom of the inspection window. That is how it should be set to give you power through the whole rev range. Have you tried adjusting the moving stroke back up to the top then see how far it travels when revved hard i havent tried that but it pulls more with that setting so i dont think it would help Share this post Link to post Share on other sites
nobade Posted December 4, 2018 If the adjuster has a lot of slop in it (more than 1/4 turn) the link arm is worn and the power valve won't open all the way. It's a wear item, costs $35, and is easy to replace. It's behind the inner cover, attached to the timer. Share this post Link to post Share on other sites
7Tktm Posted December 4, 2018 Agree it's an older bike, possible the control lever is worn where it runs up the shaft. I've re-read his last thread and it appears, if I am reading it correctly, that the control segment is at the top of the 'window', ie flap and valves closed, but when he revs it is only opening as far as the 'control' mark on the securing plate. Certainly have to remove the clutch cover and check the control lever to see if it has a half circle worn in the end and also check the ball bearings haven't jumped ramps which deffo stops the pv from opening fully. Share this post Link to post Share on other sites
