YZ compression adjuster o-ring
Yesterday I started rebuilding my 05 yz250 shock.  Was putting it back together when I broke a o-ring.  Ive looked all night and morning and still have not found a place to order the o-ring. Is this something I need to get from KYB or can I source it out at the local hardware store?
According to the Technical Touch / KYB catalog that should be
part # 120080000101, compression adjuster piston o-ring
Before contacting Technical Touch USA or a suspension parts vendor,
if you have an industrial hydraulic repair shop local to you, ask them for a 1.5mm x 25mm OD  o-ring.
Edited by mlatour
So, I have found two different size o-ring's.....
2mm x 25mm and another that is
1.5mm x 25.5mm at my local machine shop. Would I be ok using either of these?
I would try the 25.5 X 1.5 ,o rings have a decent tolerance of around 5% anyway ,buy a few
