OEMmainbearings w/ hotrods crank?
rebuilding 2012 kx450f bottom end. opted to replace all bearings with oem as their Japanese made unlike hot rods taiwanese made. anyways my crank/rod is made by hot rods and I'm reusing it, will it work with new oem main bearings? also I'm reusing the vertex piston with new oem rings. any input?
I would send a e-mail to either hotrods or some trusted shop for that question.
Or buy the cheapest used oem crank and change Rod and bearing?
just sent an email out to them. I think it should be fine, ill reply to this later with their response.
Thank you for contacting us.
Yes we have the same exact specs as OEM, so the OEM bearings will work. If you have any other questions just let us know!
  • Helpful 1
