Oset 24.0R Electric Trials Motorcycle
Have a little rideable land to screw around on, but need to be stealthy to keep the neighbors from releasing the po po on you? The Oset 24.0R Electric Trails Motorcycle looks like an interesting and serious option!
Battery Tech
The four 10Ah AGM batteries found in the 20.R were swapped out for a single 20Ah lithium ion, allowing for a diagnostics port. Of course, battery range is much less of an issue for trials riding and the new batteries are providing serveral trial course laps before a recharging.
Engine
> 1,400 watt, 48v compact engine helps keep the 24.0R down to 112lbs.
> Linear power delivery means the bike is predictable and easy to ride.
Suspension
> telescoping spring fork with compression adjustment and oil damping.
> oil dampened shock with pre-load and compression adjustability.
> Can accomodate up to a 198lbs. rider.
Pricing
> $4,389 MSRP
  • Like 2
