Maryland Jay
Stuck snap ring need HELP!!!!!
Ok so it’s a 2004 Honda Trx250ex the snap ring is in the rear brake cover. It’s stuck almost like it’s fused in and 1 ear is broke off. Thinking I’m gonna need a new cover but it’s almost $200 so I’d rather not.
Anyone have a cover for sale!
What a mess! Even if you could get the snap ring out, I don't think the cover is salvageable. Any used ones available?
keep soaking with penetrating oil and tapping it as to spin it around in the groove.  When you can get it to move you can peel it out
Edited by highmarker
Ebay
all these use the same brake plate
This Honda 43010-HM8-000 PANEL SET, RR. BRAKE fits the following models and components:
Honda ATV 2019 TRX250X AC Rear Brake / Panel
Honda ATV 2016 TRX250X AC Rear Brake Drum
Honda ATV 2000 TRX250 A - TRX250 RECON Rear Brake Drum
Honda ATV 2006 TRX250TE A - FOURTRAX RECON ES Rear Brake Drum
Honda ATV 2006 TRX250TM A - FOURTRAX RECON Rear Brake Drum
Honda ATV 2007 TRX250TE A - FOURTRAX RECON ES Rear Brake Drum
Honda ATV 2007 TRX250TM A - FOURTRAX RECON Rear Brake Drum
Honda ATV 2004 TRX250EX A - SPORTRAX 250EX Rear Brake Drum
Honda ATV 2004 TRX250TM A - FOURTRAX RECON Rear Brake Drum
Honda ATV 2011 TRX250TE A - RECON ES Rear Brake Drum
Honda ATV 2009 TRX250TE A - FOURTRAX RECON ES Rear Brake Drum
Honda ATV 2008 TRX250EX A - SPORTRAX 250EX Rear Brake Drum
Honda ATV 2008 TRX250TE A - FOURTRAX RECON ES Rear Brake Drum
Honda ATV 2017 TRX250TM AC - RECON Rear Brake Drum
Honda ATV 2017 TRX250X AC Rear Brake Drum
Honda ATV 2014 TRX250TE AC - RECON ES Rear Brake Drum
Honda ATV 2008 TRX250TM A - FOURTRAX RECON Rear Brake Drum
Honda ATV 2009 TRX250TM A - FOURTRAX RECON Rear Brake Drum
Honda ATV 2009 TRX250X A Rear Brake Drum
Honda ATV 2011 TRX250X A - SPORTRAX Rear Brake Drum
Honda ATV 2011 TRX250TM A - RECON Rear Brake Drum
Honda ATV 2013 TRX250TE AC - RECON ES Rear Brake Drum
Honda ATV 2018 TRX250X A Rear Brake Drum
Honda ATV 2018 TRX250X AC Rear Brake Drum
Honda ATV 2018 TRX250TE AC - RECON ES Rear Brake Drum
Honda ATV 2017 TRX250TE AC - RECON ES Rear Brake Drum
Honda ATV 2016 TRX250X 3AC Rear Brake Drum
Honda ATV 2019 TRX250TE1 AC - RECON ES Rear Brake Drum
Honda ATV 2019 TRX250TM1 AC - RECON Rear Brake Drum
Honda ATV 2016 TRX250TE AC - RECON ES Rear Brake Drum
Honda ATV 2001 TRX250EX A - SPORTRAX 250EX Rear Brake Drum
Honda ATV 2001 TRX250 A - SPORTRAX 250EX Rear Brake Drum
Honda ATV 2006 TRX250EX A - SPORTRAX 250EX Rear Brake Drum
Honda ATV 2007 TRX250EX A - SPORTRAX 250EX Rear Brake Drum
Honda ATV 2012 TRX250X A Rear Brake Drum
Honda ATV 2004 TRX250TE A - FOURTRAX RECON ES Rear Brake Drum
Honda ATV 2013 TRX250X AC Rear Brake Drum
Honda ATV 2013 TRX250TM AC - RECON Rear Brake Drum
Honda ATV 2017 TRX250X 3AC Rear Brake Drum
Honda ATV 2014 TRX250TM AC - RECON Rear Brake Drum
Honda ATV 2014 TRX250X AC Rear Brake Drum
Honda ATV 2012 TRX250TE A - RECON ES Rear Brake Drum
Honda ATV 2012 TRX250TM A - RECON Rear Brake Drum
Honda ATV 2016 TRX250TM AC - RECON Rear Brake Drum
Honda ATV 2018 TRX250TM AC - RECON Rear Brake Drum
Honda ATV 2018 TRX250TE A - RECON ES Rear Brake Drum
Honda ATV 2018 TRX250TM A - RECON Rear Brake Drum
Honda ATV 2002 TRX250EX A - SPORTRAX 250EX Rear Brake Drum
Honda ATV 2002 TRX250TM A - FOURTRAX RECON Rear Brake Drum
Honda ATV 2002 TRX250TE A - FOURTRAX RECON ES Rear Brake Drum
Honda ATV 1999 TRX250 A - TRX250 RECON Rear Brake Drum
Honda ATV 2003 TRX250TE A - FOURTRAX RECON ES Rear Brake Drum
Honda ATV 1998 TRX250 A - TRX250 RECON Rear Brake Drum
Honda ATV 1998 TRX250 AC - TRX250 RECON Rear Brake Drum
Honda ATV 2005 TRX250EX A - SPORTRAX 250EX Rear Brake Drum
Honda ATV 2005 TRX250TE A - FOURTRAX RECON ES Rear Brake Drum
Honda ATV 2005 TRX250TM A - FOURTRAX RECON Rear Brake Drum
Honda ATV 1997 TRX250 A - TRX250 RECON Rear Brake Drum
Honda ATV 1997 TRX250 AC - TRX250 RECON Rear Brake Drum
Honda ATV 2003 TRX250TM A - FOURTRAX RECON Rear Brake Drum
Honda ATV 2003 TRX250EX A - SPORTRAX 250EX Rear Brake Drum
Ebay
Found a 1997 trx250 recon Will that work to do the whole swing arm rear everything because my swingarm was pretty rough to
