2nd broken primary starter gear!!
Ok ya'll I have an xr100r with a 120 bbr kit on it. I have now broken 2 primary gears with this bike with in 1 year. Has this happened to anyone else? Does anyone know why this would happen? I'm not ready to give up on this bike but I'm sick of fixing it. I've read a forum on this site that said just bump start it but I'm hoping there's a different solution! Please help?!
I just broke one few months ago.  I did it upshifting coming out of a corner.
So is this just something I'll have too deal with?
Check out your compression ratio. Also are all the parts bbr. Mixing parts with the 100 is tricky. About 10.5-1 is max with these. Also check ignition timing with a light and also check the flywheel key. If the timing is off a little it can cause this also.
:thinking:  You're kicking on the kick starter while "up shifting coming out of a corner"................???   :confused:
Old School Al
Old School Al
Nope,  Shifted up and the bike locked up.  Took it apart and the primary gear broke.  Replaced it and good as new.  Tell you the truth Al, I'm to old to try and figure out why or how it happened.  I just fixed it and move on.  If you have any ideas, I'm open to them.  The bummer part was my friend from MXA was behind me and he clipped me, then we both went down, his leg somehow got caught between his wheel and swingarm and snapped four bones in his foot  (with Tech 10's) taking him out for about eight weeks.
Edited by socalxr
Quick question? Might be dumb one but I gotta ask. Is that gear necessary for the bike too run? Like can I lathe the teeth off and will it still run?
Too much octane booster sorcal ................................."Octane Arthur" has this type of thing and worse happen all the time! :thinking:
On a more serious note which gear are you calling the primary gear..........?
Old School Al
