jase12 Posted January 19 Heres a strange problem for the community, I have a bike thats failing a compression test but passes a leak down with flying colors... 2012 KTM 250 SX-F Valves spot on, clearances spot on New cam chain Dirt Tricks cam chain tensioner HAS fuel HAS spark 4% leakdown on the leakdown test FAILS compression test horribly Thoughts?? I am flat out stumped... Share this post Link to post Share on other sites
mlatour Posted January 19 What are the compression specs and what are your actual readings? Share this post Link to post Share on other sites
turbo dan Posted January 19 Were you compression testing with the throttle held open? If not, that's probably it. If so, try another compression tester. Share this post Link to post Share on other sites
KRAYNIAL My Rides (3) Posted January 19 The auto-deompression system will limit your peak compression to about 65-57psi Share this post Link to post Share on other sites
jase12 Posted January 22 Compression texting was done by a KTM tech, the reading was 15 psi and we tried two different testers to make sure. Share this post Link to post Share on other sites
Spud786 Posted January 22 (edited) 49 minutes ago, jase12 said: Compression texting was done by a KTM tech, the reading was 15 psi and we tried two different testers to make sure. I take it , the bike does not run, it wont at 15 psi. so if it runs, theres something wrong with your compression test. also how much pressure were you using for leak down test? Edited January 22 by Spud786 1 Share this post Link to post Share on other sites
Rembrand Posted January 23 Incorrect valve timing or wrong year or model piston (low piston crown). Share this post Link to post Share on other sites
jase12 Posted January 28 On 1/21/2019 at 7:07 PM, Spud786 said: I take it , the bike does not run, it wont at 15 psi. so if it runs, theres something wrong with your compression test. also how much pressure were you using for leak down test? Correct it does not run. Not sure on the pressure like I said the KTM tech just did his thing and I watched. lol Share this post Link to post Share on other sites
