J_YZ2fittyX
Decided to go back to 2-smoke.
Sold my YZ250F last fall. In the final few rides of the year I rode my buddies 2 strokes. Was a chance to see how I liked it. Liked it enough I picked up a '16 250X on Thursday! Pretty excited to go back to simplicity to be quite honest. It had a fresh top end that hadn't even really been "broken in" yet, vforce reeds, JD kit, brand new tires, suspension service just prior to being stored in a basement for a bit. The intent is to race sprint enduros and some harescrambles then mostly trail otherwise. Probably hit an mx practice day now and then. The previous owner was an older gent, but he had the trophies and plaques to prove his ability, to me at least. That said he set it up more MX suspension-wise because he rides mostly mx but loved the power delivery of the X. I plan to contact the shop he had it done by to get a run down on what all was done and their opinion on how it'll work for me moving forward. I have some plans for it myself which include:
Radiator guards (probably unabiker)
Skid plate (no idea which one yet, plan to scour this forum)
OEM pipe guard as it had a gnarly on it since he owned it, I am taking that off to put the mint oem back on that he gave me with bike.
Cycra CRM handguards (already have those courtesy of my brother in law)
Rekluse Radius X
Been going through it since I got it, tear down, clean/inspect/repack or replace chassis bearings. Going to go through the cables, etc, etc, and just make sure everything is good to go as we are planning a trip to WV in March, which, may be my first ride on it lol. Need to armor it up with the above.
What else would you guys think or are using that is a must for that type of racing? My buddy has the same exact bike, he bought the oversized tank but still has to stop for gas. So if that's the case, why bother? Debating Tubliss too.
  • Like 2
Sounds like you’ve got a good handle on armor already. Great bikes, welcome back to the smoker section.
I kind of like them a little.
Rekluse Radius X
the flatland radiator guards fit pretty seamlessly for me at $105.
1 minute ago, 2strokeYardSale said:
Threaded bar inserts for the Cycras.
G2 is the brand I have. Someone else just posted.
  • Like 2
Ask the previous owner if the cylinder head's squish band clearance was corrected.
If you find the jetting to be off for your usage
knowing that will give you an idea of what to address first.
I absolutely love my Acerbis skid plate. I can take it off and put it back on in less than 2 min. By far the easiest plate I’ve ever had and it has held up well too.
Thanks. I will ask him about that squish. He said its been runnin great. It started and sounded good when i started it. He was type of guy to go to all ends to get it right.
Will also check on that acerbis skid. My buddy with same bike hates the skid he has, so i dont want that one lol
1 hour ago, markmc2 said:
You may like the suspension. I ride an 08 yz250 with stock mx suspension on trails and some single track enduro races. Works for me.
I always ran my yz250f more mx favored. It was fantastic in trail whoops and any chop. But, when i rode my buddies 300 xc with done woods setup, it was very noticeable the difference in reaction over roots etc. My yz used to skip around on that stuff. While manageable, was noticeable. However it was much worse in high speed whoops than my yz. Can't have it all.
Will check into that. My brother in law has newer crm cycras that dont work for him with flex bars. Said i can have em.
The bar inserts prevent the handguards from rotating in a crash. It gets old having to break out a wrench or two and loosen/reposition/tighten the handguard hardware.
Ya I looked into those. Actually my buddy was saying other day that people do this. I never had before but I know what you mean, when they twist. I always had pro-bends on my yz250f but just the standard wedge-anchor type hardware. Spun frequently.
TMD skid plate.
I have the Unabiker guards. They are notorious for needing to be redrilled to fit. It’s not a huge deal, but if I were doing it again, I’d go with Bullet Proof Designs. Another advantage is their “blue” is much closer to Yamaha blue and Unabiker blue is most definitely not.
https://www.bulletproofdesigns.com/Yamaha-Radiator-Guards-s/228.htm
Another thumbs up on the Unabikers. You might poke around this forum a bit and see if there are fitment issues with an oversized tank.
Ricochet for a skid plate if you want an aluminum one.
I like the stamped Devol rear disk guards for their light weight and axle mounting method.
1 hour ago, Tahoe Gator said:
TMD skid plate.
I like Hyde Racing better because the plastic is greasy which slides over logs better. The TMD take fatigue hits and look dull pretty fast whereas the Hyde doesn't show stress marks (other than scrapes).
https://www.hyderacing.net/index.php?_route_=dirt-bike/yamaha-dirt-bikes/yamaha-yz-250-2-stroke/yamaha-250-2-stroke-skid-plate
