I just purchased a 2000 suzuki Drz400s and the carb was taken apart and there are about 4 jets and two springs that i have no clue where they go. At 12:30 ill send Pictures of the jets. im just not sure if they go to the carb or were different pieces to a carb.
Edited by Holoslove
A great resource for exploded factory diagrams is Rocky Mountain - rockymountainatvmc.com. Pretty sure you’ll have to register to search OEM Parts but we’ll worth it. Looks like you have a pilot jet, main jet or main air jet depending on size, idle mixture adjusting screw and spring (the lower screw and lower spring). Clay
Thank you for replying i just picked up the drz for 700. And the previous owner took the carb apart and was planning on re-jetting it because it was backfiring apparently. I lm just hoping to restore the carb, and I believe that the reason why it was backfiring is because one of the jets were gunked up or clogged.
Update! The extra jets and pins were not even to the carburetor i took it to a bike shop and the set the jets to the correct levels. Ill put it together and in high hopes that it runs smoothly. Thank yall for replying. A.C.
