xr200r 95+ Honda oil pump - what is the advantage over earlier style?
I don't know because the product code for the late pump is KBS, #15100-KBS-721. The casting marks on the early pump is 437, late is KSC.
The CRF230 pump is 15100-KHA-940 and replaces the 15100-KPS-900 pump so that implies that it is a replacement for the XR200 pump. And the drive gear tooth counts are different (37 for XR vs 34 for the 230).
However the product codes for both the inner and outer rotors are the same. (KPS), so some parts are shared.
   Yeah, I knew that. I got the whole pump, gear and all, when I was getting the parts to swap over the primary drive ratio to the 230's ratio (to reduce loads thru the trans). I was just hoping that I was getting a higher volume pump. I was 90% sure that the 230's pump was indeed a higher volume piece.
