You see a lot of new threads that get criticized for not checking for similar prior posts. I am sure I have been guilty before, but I must say the search feature — at least on the mobile app — is pretty useless.
For example, I am trying to figure out how to change the combo ignition cover / case saver on my son’s KX100 (same tranny as a KX85) into separate parts so as to install a proper case saver. So I type this into the Search field...
“KX85 case saver”
...and get these hits...
...none of which (nor the many more below if I scroll) are remotely helpful. I suspect this is because the Search function operates on the boolean “OR” and returns any threads that have “any” of those terms instead of “AND” so the returned threads have “all” of those terms.
Any suggestions most welcome. Or maybe the developers need to improve the feature?
“KX85 case saver”
