unkomikey
inverted fork corrosion
this is a very common problem in hawaii very hard to find a bike without it but just wanting to see if there is a way to either stop the corrosion or remove it completely IMG_9302.JPG
  • Sad 2
From all the salt? It doesn't attack the frame, too?
Never seen that, ouch...
  • Sad 1
doesn’t affect the suspension itself more of a visual thing sucks tho i love the look of the all gold forks
  • Like 2
Yeah, the frame is not anodized, the forks are, may have something to do with that. Like I noted, the frame appears untouched in the pic.
ETA, anodizing is a fast oxidation process, the oxide is an insulator. Maybe some sort of galvanic reaction going on...
Edited by RichBaker
  • Like 2
Its called layer or inter granular corrosion and only affects cetain aluminium grades
If the grain structure has been flattened by extrusion then it is more pronounced
Salt causes it
7000 series Al is badly affected by it esp 7075 which is also the strongest grade for forging
My DRZ forks are affected....I painted them to seal the surface and it has stopped it from progressing completly
  • Like 2
Salt causes it
should i scrape it off then paint it or just paint over it?
You gotta get all traces of salt off, and corroded powdery metal
I washed mined, prep'ed the surface with wire wheel fitted to drill, washed them again twice then painted with hammerite gold paint
  • Like 4
I know that if you address this before it happened, no problem.
Remove forks, spray them with high quality matte clear
5 years minimum
after you have corrosion, the best way is not an option, but...
Probably wash with soap and water and abrasive, then wipe, dry and blow off and then coat with matte clear.
If you want to make them colored again I guess you can take the forks off, than take them apart and have them re anodized or maybe have the Cerakoted in whatever color you want. Or you can also buy upper and lower fork covers and just cover them up. They make carbon fiber ones that look super nice and will be cheaper than having your forks re anodized. My forks are brushed aluminum with no coating on them and they still look brand new.  Here is a link to the carbon upper fork and carbon lower fork covers
https://www.pro-carbonracing.co.uk/kawasaki/kawasaki-top-upper-fork-protectors-kx125-to-450-all-years
https://www.pro-carbonracing.co.uk/kawasaki/kawasaki-upper-fork-protectors-kx125-to-450-all-years
Edited by Saint728
Nice ridding Crocs , remember proper safety . Always ride with Crocs in sport mode.
