I have a 2005 crf 450r dirt bike with a blown motor with un repairable cases. my question is that what years are the motors the same? I believe the "second gen" crf 450 is from 05-08. so knowing that an 08 motor is identical to an 05? just want to be sure before I got buy a right side crank case from an 07 and an 05 left crank case. any feedback will be greatly appreciated!
#projectbike #rebuildingmotorproblems
Just found a complete bottom end from a “2007” will that work in an 05 frame?
I believe you need to get both left and right side as a set. I think they are machined to fit together, preventing mixing and matching. Any pro builders who can verify this? I know it's true on my KTMs.
Tough break by the way, sorry to see that much damage.
Honda runs a center gasket so cases can be mixed and matched Frankenstein style
Same thing happend to me , bought full bottom end for £270 GBP
Cranks shot but giving it full rebuild
Unfortunately non of my cases from my bike were salvagable 4 cases gone
On plus side turns out ive already got upgraded valves and springs
Yes 05-08 same bottom ends will bolt straight in
Yes. Use the 05 headstays of course. If you where putting an 05 in a 07 frame you'd use the 07 ones.
Edited by HRC27
