Cylinder head cracked on NX650, can I use XR650L's cylinder head?
Hi!
My Honda NX650 -94 cylinder head has crack between exhaust valve port and ingnition plug - quite common failure. I have found NX650 OEM cylinder head for $1000 and that is almost half the price of the motorcycle. I was wondering could I replace the cylinder head with XR650L's own? I have found some with price tags closer to $500.
The part number is slightly different, but comparing pictures, they look identical. Have you done this, have you heard anyone that has done this before? Do you know a thread were they have talked about this?
Cheers!
13 hours ago, Mukavastinumb said:
Hi!
Cheers!
Make sure all the parts you need are included in the head deal.......... guides. ect.
Can you use your old valves and springs....................I would get new ones......
