2019 KTM 690 Enduro R Recall
They need to try swapping the ECU with another 2019 to eliminate that part of the equation.
Can you replicate this same problem on your 2019 model 690 ? As I’m being told that there isn’t a problem. I think the real problem is the bike is a new model and they don’t know what to do. Getting support From the factory is very slow
If they say there is no problem the you need to determine the revs per minute the limiter is coming in at so you can tell them its definitely coming in too early. I have had mine at the rev limiter and it revs fine
6 hours ago, Cookie 45 said:
just got home from work and listened to the video on my computer and it sounds like the limiter is coming in at the right time. Sounds like you are slipping the clutch when you are reving it am i right or is there also a clutch slippage problem? Also the maximum revs on this bike is 8000 and you get max power at 7500 so not much space to play with. have you got the bike back from the dealers.
Edited by Renegademaster
Bike still at dealer. As it doesn’t have a rpm gauge I need to add a multimeter to see at what rpm the limiter comes on. My concern is I rode the bike for 1200km in some tough terrain known as High Country Victoria and never had any rev limiter issue ( completed the run in km’s as per book ) for example if I do a power mono the bike will not perform as rev limiter kicks in. If I have a shoot out with friends also bike will not perform as previously for same reason.
Will keep you posted
Any resolution yet ? 1st oil change this weekend-
Still at dealer and no response from KTM AUSTRALIA as yet. Will post with update soon
On 6/18/2019 at 7:23 AM, Islandbouy said:
My 2019 KTM 690 enduro has been in the shop for three weeks for a separate issue (check engine light).  Are you in the US or Canada?  Today Austria engineers are dialing in for the third time.  I have no confidence in this bike and have asked for a replacement cause the dealer, ktm Canada, and Ktm Austria cant figure it out.  I will find out today.
Well after many attempts to troubleshoot this check engine light KTM Canada is replacing my bike with a brand new one. It took many phone calls and lots of persistence but KTM finally came through and did the right thing! New bike should arrive in 2 weeks.
  • Like 2
KTM couldn’t fault the rev limiter problem. So collected bike and just now I found the airbox air intake sensor wires squashed under the battery bracket bolt. would damaged wire cause the motor to hit the rev limiter early ? IMG_4807.JPGIMG_4806.JPG
I got my 2019 690 enduro r 2 days ago. It has less than 40 miles on it and today it stalled on me and then wouldn't try to start. I turned it off and waited 30 seconds and it started fine but now the engine light is on.  I let it cool down and later came out and started it and the light is still on.. I hope this isn't something too difficult to remedy, I bought the bike for the TAT ride im planning. really counting on it to be reliable. I'll update you guys as I hear as I'm sure you are on the edges of your seats.?
  • Like 2
Did fixing the wires fix your problem?
I ended up fitting the RADE 5.5l subtank and airbox and rewired the crushed wires in photo.
Now the Bike is an absolute weapon with Wings exhaust, Open / breathable twin air cleaner filter fitted to the RADE Garage airbox. Please note : Keeping the original OEM airbox restricts the engine considerably and a higher risk of dusting the engine due to its design.
Now that i have plenty of power for my style of riding with 14/48 gearing, the rev limiter issue is no longer an issue. Love the bike - just had to derestrict the engine of its heavy emission controls for EU.
I just put in the Rade intake and at idle the bike will die sometimes with a light blip of the throttle. Wings exhaust with DB killer. While riding it seems to be OK but not sure if it's getting too lean or what.
Edited by Augmach5
I have experienced once an engine shutdown on a decline no throttle - seems like the same issue. Not a major issue at this stage
Picked up my bike on October 11, went for the first break in ride and mine exhibited the same symptom as yours Arron, at about the same mileage. The light did shut off on the third start. Can’t shut the traction control off, so that seems to be a common problem. Will take it in and see what wisdom comes out of it.
I was curious if you got your bike figured out, and if so, what was done?
On 8/18/2019 at 4:43 AM, Cookie 45 said:
the original OEM airbox .... a higher risk of dusting the engine due to its design.
Can you explain this?  Where do you see the risk of dust getting past the filter in the OEM setup?
My '14 leaked between the filter rim and the air box. This has happened with both the stock and aftermarket filters.  The air box top tends to bend at the center when screwed down allowing unfiltered air flow. Carefully and generously greasing the lip where the filter sets mostly cures the problem.
3 hours ago, Flagstaff said:
The air box top tends to bend at the center when screwed down...
I've noticed the same bending of the airbox lid on my '19, but the edge of the filter element seats firmly into the groove on the airbox itself, so the small open gap between the airbox and the lid lets air in upstream of the filter, not past the filter, as far as I can tell.
Mine lets it in through the bottom of the filter flange, downstream, grease applied here does work for me. There really is no other place for it to leak from to coat the upper portion of the air box. I think the filter, regardless of manufacturer is bending along with the lid. :excuseme:
