Rear tire max size, 89 rmx
First try lowering the pressure to 10-12psi
120 versus 110 wide has some pros/cons
A wider may offer better straight line traction but a narrower tire will usually work better at everything else (handling, cornering etc.)
So a different tire, same size?.
Try adjusting your technique. Roll on the throttle a little more carefully. Or run the bike one gear higher.
Other things you can try are backing off a bit on the rear preload/compression dampening, lowering tire pressure, different tire/softer compound.
Ok, I softened my suspension a tad. Ordered the Pirelli u-all recommended, went with 110/100/18.  For sure its softer than mine, its 10+ years old. Had a cold spell here in east TN, fire in stove, tire warming now for install. Glad I did this, found a leak in tujbe, patched now. If the brandy don't  get me first, itll be installed tonight? Benn a while since I had a new tire, best I remember, they HOOK Extremely well, for a while? Report back tomorrow, mabe( gotta take kids to egg hunt first?  ).
QOk, I softened my suspension a tad. Ordered the Pirelli u-all recommended, went with 110/100/18.  For sure its softer than mine, its 10+ years old. Had a cold spell here in east TN, fire in stove, tire warming now for install. Glad I did this, found a leak in tujbe, patched now. If the brandy don't  get me first, itll be installed tonight? Benn a while since I had a new tire, best I remember, they HOOK Extremely well, for a while? Report back tomorrow, mabe( gotta take kids to egg hunt first?  ).
