Needle drop test on Keihin PWK jet block
I’m sure most of the kdx guys have seen the video. But there’s a theory that the depth a needle falls into the jet block can be used to determine if the block itself is so worn that the carb is basically untunable. I have a carb that doesn’t respond to air screw adjustments and is only able to idle with the idle screw all in.
What everyone’s thoughts?
Edited by Tmosely1
depends on how that compares to a new one....maybe.
I would guess that the majority of wear is in one sector and you may not see a significantly different reading even with a very worn jet.
