2007 kx250f no spark ? Help!
Hi i have a 2007 kx250f that has no spark and just quit running! Valves are within spec, timing is dead on. Changed plug and coil pack, cdi, kill switch, complete frame harness, stator! What are the chances it could be the flywheel or neutral safety switch? Thank you
It seems you have gone through all the electrical aspects of the sparking issue, so it must be something mechanical. I would try the neutral safety switch just for the hell of it and if that fails too then it doesn’t make much sense but try a new flywheel
I tried the neutral safety switch tonight and still nothing! Im going to pull the flywheel off tomorrow and swap it out!
